Old 06-09-2013, 02:16 PM   #2
JFP in PA
Originally Posted by woodsman View Post
hello, I bought some lines from Pelican and have installed one but it required tossing the OEM retaining clip. Now the line floats in the bracket that's attached to the inner fender. I know this will cause wear in the future and wonder if anyone has used these and found a solution that will remain in place despite the harsh environment it's in.
Also, I previously read Wayne's DIY article on the Pelican Parts site on Stainless br lines but cannot locate it now- is it gone? I can locate the article for rubber lines only.
You should not be running the car with the line flopping around, the clip needs to be there to hold it steady. I have never seen a quality stainless brake line kit that required tossing the OEM retaining clips................
