Old 06-07-2013, 06:18 AM   #4
EssexPorsche
EssexPorsche's Avatar
MH.
Perfect kind of depends on the eye of the beholder?
Some like their wheels tucked in, less road rash etc etc, whilst others like them to run pretty flush with the fender?
So the perfect offset is not easily defined.
If you want to run flush, and without spacers as suggested by flavour - dig out a thread between JD and Porsche Pete. He ender up with 19" Victor Khans and the fit was sooooo good with no spacers.
You also need to consider if you intend to lower your car as this too can have a bearing on how wide you can run without rubbing - unless you run PSS9 dialled to rock solid!
Its not a clear cut formula.
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
