				Quality body work, Celette machine
			It seems my PO had an indiscretion involving the right rear. Officially was described as a "minor collision." I duly noted this at purchase, but was not put off b/c I couldn't see anything significant, the paint work looked good, and the only defect was a slight rub between the rear trunk lid and the spoiler, which I thought I could address by adjusting both.  Not so. It rubs paint but doesn't affect function of either.
So now I would like to fix this properly.  I don't know which parts of body/frame are affected, as the shift is pretty slight. But there was fairly liberal use of seam seal around the back of the rear tub. Wheel alignment hasn't been an issue.
Some research suggests I need to find a body shop that has a Celette machine and the 986 jigs, to make sure this is done right.  It looks like Jim Ellis in ATL has one. Does anyone know of any others in the AL/GA/TN area?  Any info or other thoughts/opinions are welcomed.  Thanks in advance.
