I thought about this the other day to determine where the problem may lie. Put your top up, but don't latch it. Stick your finger in the latch mechanism and feel the switch thingy. If you push up on the switch (Car thinks the top is closed and engaged) and the light goes out, I would feel safe in assuming your problem is the switch is starting to go bad and possibly wedging something in there may solve the problem temporarily.
If by pressing the switch, the light does not go off... I guess the problem is still the switch, but it would need to be replaced.
I'd rather someone else in the know helped out here as I am just a novice (so far) when it comes to such things.
