Old 06-05-2013, 12:24 PM   #13
JFP in PA
Originally Posted by southernstar View Post
Thanks JFP, makes sense. But in removing the outer seal, shouldn't one also be able to inspect the bearing for damage without removing it?
Brad
Yes and no; you will be able to see part of the bearing, but that is about it. It is difficult to get a magnification device in there to look at the races and balls for signs of pitting or wear. We have seen bearings that looked good in the car, but after extraction and a good cleaning looked a lot different. So running the existing bearing is a bit of a crap shoot for everyone short of the 2005 and on cars that cannot extract the bearing through the cases. Even then, Raby has developed a way to upgrade those engines as well, but only does it at his shop.
