Old 06-05-2013, 11:23 AM   #1
adream8
Found the problem, guys!
Not that anyone responded.. :/
It was the AOS. It's diaphragm had begun to tear. Was sucking air into intake and creating a strong crankcase vacuum, substantially above what it should have been. Could barely budge the oil filler cap when the car was running.
Fortunately (and amazingly) there was no oil yet in the intake, so I was safe. And lucky.
Replaced the AOS, and now all the parameters (including fuel trim) are back within spec and the car is running perfectly. DO notice a difference in performance.
Figured I'd post, just in case it might help anyone else down the line.
Now I just have to change the oil and swap the engine mount out, and she'll be all fixed up.
adream8 is offline   Reply With Quote
