Old 06-04-2013, 11:11 AM   #13
southernstar
I'm 5'11" (I've shrunk a good inch due to herniated discs and the ravages of time), 168 lbs and yes, I find it comfortable. The seats are a bit tight in the area of the upper body, but that contributes to them holding you in place in hard cornering. This is not a GT (grand touring) car, it is a sports car and it is obviously not going to be as comfortable on long trips. To accomplish that they would have had to soften up the suspension, install more sound insulation (with more weight!) and install wider seats with adjustable lumbar (and again, with more weight), all of which would have detracted from its primary intended use.
Brad
southernstar is offline   Reply With Quote
