Hey guys sorry to open up a old thread but I have a very similar problem so I thought I would post it up here and maybe find some help. Here is what I got I just purchased a 2000 Boxster S with 62,XXX miles on the clock and on the PPI they said it needed the 60k service and a oil air separator. I decided to perform all the work myself Plugs, belt, air filters, fuel filter, Oil air separator, Oil change and filter, I also took the throttle body off and cleaned it with carb cleaner. My buddy came over as I was getting done with the car and taking it off the stands and had a OBII code reader that we plugged into the car after the initial startup and cleared the codes since I replaced the oil air separator which had a bad hose causing a vacuum leak and I wanted to see if the CEL would return for any other reasons. The car seem to idle fine before we cleared the codes but didn't try to rev or give it any gas but after we cleared the code he said turn the car off and turn it back on but when I restarted it the car it idled really ruff and won't take gas. It seems to idle up and down from 700ish-1200ish. I can barely press the gas and get a smooth idle at 1000-1200ish but won't take any more gas then that. Note that we took the battery negative off for 20 mins hoping that would reset the computer or whatever is causing the erratic idle and throttle not being responsive. Thanks in advance
