Also suspect you are about to find out that there is no market for the used roll bar. It looks like it should have a value but I literally couldn't give mine away and ended up throwing it in the garbage.
Definitely a lot easier to de-wire before the cage goes in. Simply find all the wires that now go nowhere and start unwrapping and trimming until you find your way back to the source. It's a lot easier than it sounds. In the end you'll find you only need about 6 - 10 (depending on your choices) of the fuses and only 1 relay up front (fuel pump) and 2 at rear (ECU and something else that escapes me right now). Even if you leave the immobilizer in place you'll discover that there is only about 8 of the fifty something wires currently running to it that you actually need. In my case I chose to leave the complete engine harness in place all the way to the ECU but forward of the ECU everything that went nowhere (including to a fuse that then went nowhere) was taken out. I ended up with a full domestic garbage bin filled with almost 40lbs of wire/blocks/fuse box etc. I built my car on the basis that all it needed was a motor, wipers and brake lights from the original wiring. Everything else is gone.
