Old 06-02-2013, 07:50 AM   #10
JFP in PA
Originally Posted by shadrach74 View Post
Agreed. My initial biases got that better of me. It was not a conscious mistake i assure you. My apologies!
Still no one has answered my initial question about the heater circuit and if it is independent of the thermostat.
OK, then I'll answer it: First, the heater core is always "on", meaning it has circulation even when the AC is running, but that circulation pathway changes during warm up. The M96 has a bypass coolant circuit that allows some low level volume of coolant to circulate while the thermostat is fully closed. This circuit is actually there to help prevent head cracking as they get hot very quickly. As soon as the stat begins to open, much warmer coolant begins to flow at a much higher volume rate, giving the driver much more heat.
