Old 06-01-2013, 02:17 AM   #12
shadrach74
Originally Posted by AKnowles View Post
FWIW, I used the Bently method while I was flushing with distilled water. Then ordered a vacuum system for the final fill. Was much easier and had no worries about air bubbles. For the $100 I seriously recommend one. Particularly if you plan to add a third radiator as I do (just need the front hoses and one more frame bracket) or a flush and fill every couple of years.
This...^^^
I have one and it makes a huge difference, but you will still need to pull the coolant bleed valve and drive it for a bit.
shadrach74 is offline   Reply With Quote
