Old 05-31-2013, 04:43 PM   #4
Steve Tinker
Steve Tinker's Avatar
I'm with Phil - the usual culprit is a loose or poor high resistance connection (the fuse's spade connector springs to mind).
Most times its obvious when you pull the fuse / connection block as you can see the burnt PVC insulation & discoloured copper where the heat started.
2001 MV Agusta F4.
