Old 05-31-2013, 04:32 PM   #11
BYprodriver
BYprodriver's Avatar
Originally Posted by Wilson01S View Post
That looks just like the tensioner I inspected. What tensioner do I need to remove in order to take the cam gear and chain off the drivers side head?
Also what is the "test" for the lifters? I will submerge them in hot oil, but is there anything I should look for, or is there a certain amount of pressure they should be able to hold?
The 4-6 cyl. chain tensioner is on the top side of the head. In the picture below it's next to the cam position sensor. It's under the A/C compressor.
Let the lifters "cook" for a good 8 hours at about 250 degrees. Press down on the plunger to purge the old oil, you will see dirty oil squirt out, keep pumping until no more dirty comes out & the plunger gets too hard to compress again. You might need to add a quart of Marvel Mystery oil to the pot.
