Old 05-31-2013, 08:22 AM   #2
Homeboy981
Homeboy981
Homeboy981's Avatar
OK, here goes: The thermostat sets the baseline minimum operating temp for the engine; it is the temperature the engine returns to when running at a steady state (road speed air flow across the radiators). Because of the convoluted design of the M96/97 cooling system, particularly the engine passages themselves, these engine's typically run a bit hotter than the temperature at which the thermostat opens. As the result, with the OEM stat opening at 186F, it is not unusual for the engine to run 210-215F at steady state on a fully instrumented 986 (forget what the dash gauge say, they are well known for being both woefully inaccurate and non linear). Because of the cooling system layout, at that temp the engine is actually much hotter in some internal areas, and as the oil is always hotter than the coolant (even though the engine uses a oil to water heat exchanger).
Changing to a 160F stat tends to lower the steady state coolant temp to around 175F, and more critically lowers the oil temps by over 25F, which the oil likes much better (UOA's before and after have shown the oil actually shows better parameters for longer distances between changes with the 160F stat). And on a base car, adding both the 160F stat and the "S" oil cooler (nearly twice the capacity of the base unit) improves the oil life even more. In essence, lowering the coolant and oil temps translates into improved life for both the oil and the engine.
And once and for all, cars with 160F stats do not warm up more slowly; in fact, the tend to warm up more quickly as the warmed coolant starts to flow sooner, not later.
What he said, And….IF you are added an UD Pulley, the water pump will be spinning at a slower rate, so you need all the help you can get REDUCING ENGINE TEMPS. A cooler engine produces more power. All I know is, I put a low-temp thermostat in and it seems to run better, warm up quicker, and WHEN IT DOES GET REALLY HOT OUTSIDE the temp of my vehicle may go up a bit higher than normal BUT it stays UNDER the hottest temp that the higher thermostat allowed. In other words, the engine temps don't seem to get AS HOT…cooler = faster.
Sorry but that explanation was anything but fast.
Kashmir…what the heck is that swimming on your seats?
