Old 05-30-2013, 01:12 PM   #27
Topless
Track rat
Topless's Avatar
Originally Posted by jaykay View Post
Anyone? This will affect wheel rate as there is larger moment on the arms.... Effectively softening the springs a touch.
The spacers will screw up the alignment I am told.
Putting them back on after will also change the track, maybe effective contact patch, corner balance....yes?
Talking about using wheel spacers for a wider track? It will change suspension marginally but probably not enough to notice. I would run the car first without, as long as the wheels fit. Add spacers after you have a good baseline on your setup and compare results.
