My 99 has 146,000 miles. If you can self perform the work it's not that bad on cost.....higher than most cars but doable. Oil change will run you around $80 to do yourself. PPI is very important. Records are VERY important. $7900 ..... should be some wiggle room there. Would look at around $6500-$7200 if all checks out
