Old 01-13-2006, 08:09 PM   #18
deliriousga
deliriousga's Avatar
Originally Posted by eslai
I'm a bit confused and maybe the owner's manual would clear it up, but do the jack stand pegs and the floor jack pegs that y'all are talking about fit into the same exact hole? Or is there a seperate hole for the jack stands to fit into than the one that the jack is supposed to use?
Just trying to see how you'd put a jack stand under one end of the car when the jack is in the way. Haven't been underneath the 987 yet...
There are only 4 holes for lifting and putting on stands. The way I get it on all fours is to lift the front by putting the jack under the rear holes then once it's up in the front I put the jack under the cross bar that runs under the back to lift the entire rear and put the stands in the holes.
1966 Wife White/Brown Top
