Thread: Used Engines?
Old 05-24-2013, 07:05 PM   #1
thom4782
thom4782's Avatar
I don't know enough about used engines to comment directly.
That said, I would suggest the following. There are a number of relatively cheap used Boxsters available for sale these days. Find a car you like. Get a PPI inspection done before buying. If you're concerned about the IMS question, replace it with an LN Retrofit. While you're at it, replace the clutch and RMS. It will cost $2K to $3K total. Then you'll have 60,000 plus worry free miles with an engine you know far better than some used one from a wrecking yard.
BTW: Maybe you'll get lucky in find a used car with a LN Retrofit already installed.
