Old 05-24-2013, 01:31 PM   #23
Homeboy981
Homeboy981
Homeboy981's Avatar
Originally Posted by woodsman View Post
As I lay my head on the pillow last night, I suddenly remembered that without the tranny in, there's only ONE ENGINE MOUNT!!!!!Something to consider before starting 'er up Homeboy.
Also, I 've found a 'release arm pivot' piece ( looks like it's a NON-pivot piece actually) on Pelican that my car doesn't have- maybe yours doesn't either???
Hi Woody,
Thanks for thinking of me BUT you are putting in way too much time! Don't take your problems to bed, take your wife instead…IF she is your problem, then you still have a Porsche! My wife is GREAT…so I can't even spell Porsche when "my head hits the pillow". Another story.
My Pcar is a 6 speed not sure IF it has the piece of which you speak. I got a whole kit from Pelican and installed a new release arm with the clutch. Even replaced the little rubber thingy and spring.
Essex,
All my mounts are new. Transmission and motor mounts have been replaced in the last 15k miles or so. Since you may not be familiar with the LWFW…YES the DO vibrate quite a bit. "gear lash" is technically what it is referred to as. That is why you need a dual mass - although it is double the weight! That is also why some older members do not recommend them.
Saw others do it without problems and thought I could too. Ah well, I will take it on the chin and put the old one back in!
Anyone feeling lucky and wants an Aasco LWFW for around $500 - let me know! It has around 1,000 miles on it. I will even include a clutch and pressure plate with same mileage. It's like getting a clutch and pressure plate FREE or only paying a couple hundred for a LWFW. The Aasco is re-buildable too, you can replace the friction material.
Thanks for all the efforts. i will try to eek out some time to turn a wrench this weekend.
No fun to write and not drive!
