Old 05-24-2013, 01:06 PM   #10
BYprodriver
BYprodriver's Avatar
Originally Posted by Wilson01S View Post
How much should the chain tensioner (nearest the oil pump) be able to collapse? It barely moves 1/4" and becomes rock hard. Doesn't appear to be any cracks on the contact pad inside the engine case, and the wear pattern is central on the end of the tensioner.
Is this the tensioner with the spring preload plunger? You should be able to compress it 1/2" - 3/4". To properly test it, place in hot clean engine oil 2" deep & pump the plunger. You should see dirty oil coming out making room for clean oil to go in.
Easiest to do this in a electric cooking pan @ 250 degrees.
