Old 05-24-2013, 09:24 AM   #15
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by shadrach74 View Post
BTW, the deflector in your pic looks like it belongs to a 987, which is why it won't fit your 986. The previous owner probably bought the wrong one...
Whippy, what he said.
The 986 deflector, at least the early ones (what year is yours, btw?) has a small divot in the upper center of the glass to allow the top latch to pass by without contacting the deflector. Later versions were a straight and solid piece of glass because the top now moved high enough that there was no risk of contact. So sell the one you have to someone who needs one to take a bit of the edge off of the cost of picking up the right one for yourself.
So by your pictures you do have a deflector, just not the right one.
When you buy the deflector, it should have some small little handles on the upper right and left sides, which are what clip into the roll hoops and are what you pull, while pressing down slightly on the deflector, to release and remove it when you want to. Everything else is already in place for you.
-O/D
IMSR + RMS
Robbins glass window top
