Old 01-13-2006, 07:04 AM   #1
MNBoxster
Originally Posted by Tool Pants
Hi,
That's the EXACT Jack Pad I have too... works Great, with the exception that the combination of my Floor Jack (Craftsman 3.5 Ton) with the Jack Pad is about 2mm taller than my '99 when the Jack is fully retracted - no problem - I use the Scissor Jack from my 240Z to raise the Boxster an inch, then slide the Floor Jack & Pad under. Once I'm done, the Car doesn't settle 'til it's driven, so the Jack slides right out. I have considered shaving the 2mm with a File from the Center Prong on the Jack Pad, but so far have been too lazy to do it. I particularly like the Nylon spacer rather than a Rubber one - more robust...
Happy Motoring!... Jim'99
