Old 05-22-2013, 09:52 AM   #1
Ckrikos
Ckrikos's Avatar
At 60k your brakes should be ok, you should be on the original rotors and second set of pads. The rotors will be forming a lip at that mileage and will be 10-20k before needing replacement. Are the tires ok? I just replaced mine, 2nd set at 50k miles (fronts were originals).
I'm not sure if the IMS bearing can be replaced on a 987, but it should be checked if you are changing out the clutch.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
