Old 05-22-2013, 10:49 AM   #13
Homeboy981
Homeboy981
Homeboy981's Avatar
Originally Posted by woodsman View Post
you said;' it was definitely in the tranny' when I implored you to listen closely before taking 'er apart. I wonder if you could run the engine without the tranny in? then you'd know which it is. I know from first-hand experience that sounds travel and bounce off things in cars. Does the tranny look like it's been apart and if so , did they forget something?
Hi Woodsman,
Can I run the engine without the tranny on? I need to put the flywheel on for starter to engage…but that is a possibility to try the old Dual mass FW and see IF it still make noise.
The tranny does not look like it has been rebuilt. Of course, I have heard that the LWFW can cause some issues, maybe it rattled the transmission to pieces? It is curious I first heard the noise between shifts and then 'out of gear' and now ALL THE TIME!
