Old 05-21-2013, 07:12 PM   #1
Kenny Boxster
Moderator
Originally Posted by desert_porsche View Post
You are correct that there are two clutch switches. It is very possible the other switch is causing the fault. Did you check fuse B7? Try replacing the other switch.
Fuse is fine, went and ordered another clutch switch. Was hoping someone on the forum had the same fault code and found out what caused / fixed it. Seems very odd a clutch interlock switch to start the car would cause a noticeable lag in second.
