Old 05-20-2013, 03:39 PM   #1
peraspera19
How to Fix Broken Lock Cylinder for 20 Dollars
A few days ago, I tried to manually unlock my 2001 986 and the key
turned with no resistance. A quick online search mentions that the
solution is usually one of the following two issues:
1. A broken plastic piece (Part 12 Here (Porsche Boxster Door In White Parts))
2. A broken metal piece in the lock cylinder, which requires replacing this piece (Part 15 Here (Porsche Boxster Door In White Parts))
You can easily replace (1), as the part is available online. After disassembling my door
panel, I realized I have problem (2). Of course, Porsche doesn't sell the $0.50 piece of
metal by itself - you need to replace the lock support for $350. Tons of dealerships and
junkyards sell the entire handle (with lock cylinder) for ~$100 to profit from this fairly
common problem. Again, this is a suboptimal solution for replacing a very inexpensive
part.
Here's how to fix it for ~$20:
Porsche and Volkswagon share many parts, and as it turns out, Volkswagon is
much more reasonable about repairing a lock cylinder.
1. Order RegulatorFix VW Passat Audi A4 (B5) Door Lock Repair Kit
(RegulatorFix VW Passat Audi A4 (B5) Door Lock Repair Kit - Front (left or right) : Amazon.com : Automotive) from Amazon.
2. Disassemble the door panel and remove the "back" (support) for the handle
and lock cylinder (bring a torx wrench set).
3. Remove the lock cylinder, and (by pressing down on the paddle/screwdriver piece)
slide the quick release washer off.
4. Replace the inner metal part (if broken) shown in this Porsche Lock Replacement - Imgur
photo (duplicated at bottom of post). The old broken piece is yellow, next to the
identical silver new piece.
5. Save $300.
Hopefully this will help others save money in the future!
peraspera19 is offline   Reply With Quote
