Old 05-20-2013, 12:58 PM   #2
JFP in PA
Originally Posted by Wilson01S View Post
I have searched around now and found a few different answers, and several great threads; however, I have also now confused myself.
Question 1.)
Is a 2001 S 3.2L a 3 or 5 chain engine?
Question 2.)
What special tools will I need to remove the camshafts, and replace lifters so that I can properly re-time the engine?
I have seen kits from SIR Tools, Porsche specific tool numbers, and a few others. I just want to make sure I have all proper tools, so that when the engine is out to do the repair I don't strand myself.
Thanks!
1. A 2001 is a five chain motor.
2. You will need a cam holding tool (so you can remove the cam cover), and cam timing tool (so you can dial the cams back in after replacing the lifters). These tools are not interchangeable.
This entire procedure has been written up multiple times, showing home made replacement tooling for some of the OEM stuff.
