Originally Posted by kjc2050
Mountainman,
How high is your garage door? Is your garage considerably larger than a "standard" sized garage? Thx for your help.
I have a standard size 8 ft wide by 8 ft tall door and the ceiling height is 9 ft. It works with a couple of inches clearance for both cars. Lift and jack together was about $2500 delivered from greg smith equip. If you notice in the picture You need enough length in your garage so the lift can be positioned far enough in that the trunk or hood area is under rhe garage door opener and not the roof or it will not clear.
