Originally Posted by SolidWorks Mike
Just buy the $35 ones from Pelican. That's what I have used and they work fine.
If you find that the cups are constantly breaking, then the alignment is off and needs to be adjusted. The cups are plastic to serve as a weak pint that will break instead of damaging a $300 motor or gear.
Thanks for the tip. Ill search for top adjustment.
Originally Posted by AKnowles
THank you
