Old 05-19-2013, 04:45 PM   #2
kjc2050
kjc2050's Avatar
Could be a belt tensioner. Remove the belt (mark its direction with a piece of chalk or something similar before removing, and make sure you install it with the same orientation). Rotate each tensioner by hand and see if you feel any resistance or hear a grinding noise; if yes, it needs replacement, which is fairly easy. Also, of course, check the belt itself.
