Old 05-18-2013, 06:32 PM   #17
drbodzin
San Diego Boxster
drbodzin's Avatar
Cool
Then is was on to installing the clutch and pressure plate. But first I had to tighten the flywheel bolts. In order to do the the 120 degrees after torquing to 19 ft-lbs I used an angle measurement tool. I tried to locate the printed degree wheel from 101Projects.com, but it impossible to find it. So I had to improvise.
Locked the flywheel with a $0.75 metal strap from Home Depot. Worked great.
Attached the angle measuring tool (has a magnet) to the side of the breaker bar and noted the angle. Then calculated what the angle would be after 120 degrees. I think I liked using this method a lot and would recommend it to any one else.
I'm installing a new clutch disk and pressure plate for the 987 instead of the 986. Read that it was a nice upgrade.
Guess there is a side that is suppose to face the trans. Make sure you install it the correct way.
The new 987 pressure plate.
All done with the clutch install.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
