I don't think the Box is hateful to work on, and I think it requires little in the way of specialty tools for normal maintenance. A lift makes it a far better experience. I'm currently using jack stands and have about 17" of clearance which is sub optimal.
I do think that Porsche skimped on the fasteners. The roll bar covers are a case in point... those threaded shaft friction fittings are a lousy design that requires a pry bar to remove them. Very crude, and one of mine broke in the process of removing.
Easiest cars to work on in my opinion are the pre-1992 Mercedes Benz products. Beautifully put together machines that are easily disassembled. I once installed an alternator in a 89 300E in a parking lot at midnight when a buddy was stranded. 1hr from start to finish. I've also worked SELs and SLs as well as a 190E 2.6. They were all great cars that were great to work on. None of the Euro or Asian cars of today are built with the same philosophy. These days you're drilling out pop rivets to replace a window regulator or pulling a timing belt to get to a thermostat. I think the 70s and 80s were the last of the golden years for German autos...
