Originally Posted by thstone
Corner balancing a car with stock suspension is impossible because the ride height is not adjustable.
i'm gonna go read again, but i remember reading that the car has to be balanced and aligned with 165lbs in the drivers seat to facilitate the best possible handling, regardless of suspension setup. i could be confusing it with the track suspension information i was reading also.
EDIT: if it's factory suspension, you could also be suffering from sag due to the age/wear of the suspension.
