The fronts are in very good shape, rears are 50-60%. The bolt patterns are the same, and I did a little research and it appears that the wheels should fit fine, but you may want to look for yourself as well.
The specs on these wheels are front 8 x 18 with 57 mm offset and rear 9 x 18 with 43 mm offset. Which wheels does your car have? If you can find out your wheel specs, this tool will tell you if spacers are required: 1010TIRES.COM - Wheel Offset Calculator
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
