This appears to be an accurate set of specs for the oem version of that wheel. Assuming that the replicas are the same, the rears will provide a very good offset for your 986. However, +57 is rather high. I would suggest lowering the offset by 10mm or so with the appropriate style spacer(s).
Front Wheel: Part #: 987.362.136.01 Size: 8.0Jx18" Offset: 57
Rear Wheel: Part #: 987.362.138.01 Size: 9.0Jx18" Offset: 43
