From what I have read, the S axles are longer than the base Boxster because the 6 speed gearbox output flanges are further back than the 5 speed. It makes the halfshafts angle forward at a weird angle which is why the CV boots go bad faster on the S models.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
