Old 01-11-2006, 04:09 PM   #4
MNBoxster
Originally Posted by deliriousga
I saw pics of it on the Paragon site. Can the covers still go in over the bar in the front trunk?
John,
The Bar sits directly behind the Battery and does not interfere with the Inspection Covers at all. Easy install - remove 2 of 3 Bolts (13mm) from the Struts (keep the one tight to prevent losing the Camber Setting). Install the Brackets, retighten Strut bolts to 26 ft. lbs., and then attach and adjust the Bar. Total time - under 10 min.
Happy Motoring!... Jim'99
