Old 05-13-2013, 04:33 PM   #15
Steve Tinker
Steve Tinker's Avatar
A lot of people confuse "burping" air manually out of the cooling system by just running the engine for a few miles, which is incorrect.
Ridding the closed system of unwanted air pockets require several heat cycles with the vent valve lifted open. The engine must reach normal operating temp with the thermostat fully open, and then let the coolant cool to ambient temp. This "cycle" must be repeated at least 3 times (still with the vent valve open) to rid the system of air, with topping off the level of the coolant as required.
2001 MV Agusta F4.
