Old 05-13-2013, 10:06 AM   #10
Perfectlap
Perfectlap's Avatar
Originally Posted by southernstar View Post
Pedro on Pedro's board has over 200,000 miles on his original pump and he believes that some of the early pump failures are due to people occasionally opening the coolant reservoir cap when the engine is still hot. It is, of course, supposed to be a sealed coolant system and he believes that bubbling when the cap is removed can lead to air locks (as well as reduced coolant due to vapour) that ultimately cause failure of the impeller. His rule is to never remove the cap; if coolant is down, there is already an issue.
Brad
Good to know.
Pedro also pointed out that flushing the coolant needs to be done precisely, if any air is in the system the original and probably brittle coolant tank with split within a year or so.
Might have been coincidence but that's exactly what happened to me. I ended up spending $1,000 on the flush and new tank within 12 months of each other, I probably should have done the watermpump then too.
BORN: March 2000 - FINLAND
