Old 05-13-2013, 02:06 AM   #6
Meat Head
Buy the cheaper ones. It is not hard to get everything synced back up so don't worry.
Thanks for the encouragement. I have a tendency to panic when things like this go wrong. Convertible tops are not something I'm used to working on.
Maybe this is a dumb question, but is there any position the top and clam shell need to be in when I connect them to the linkage (after I sync the boomerang brackets)? Also, how do you adjust the push rod. My passenger side was completely disconnected and the adjustment slide loose so I don't have a measurement to go off of. I guess that I'll adjust it to the same length as the drivers side push rod??? I can't seem to find any info on this???
Does anyone know the part number or where I can find the little clip fasteners that are used in the clam shell linkage? I've seen it called "guide lever SL lock" or "Deck lid fastener" but I cant find it at Pelican??
By the way, I figured out why it got all jammed up. When the top was in the down position the boomerang bracket (portion connected to the pushrod) had rotated all the way up to the point that it contacted (wedged) the fender body panel. I'm wondering if my micro switch that tells the motor the clam shell is down is broken and allowed it to continue pulling when it shouldn't have.
Meat Head is offline   Reply With Quote
