Old 05-12-2013, 09:40 AM   #8
Bruce Wayne
Bruce Wayne's Avatar
Here in SoCA where it only rains in winter I replace my tires when the rubber is worn thru & cords appear.
oh you'll like the UK laws then..
Minimum Tread Depth
The requirements in the UK are that the grooves of the tread pattern of every tyre fitted to a vehicle shall be of a depth of at least 1.6mm throughout a continuous band comprising the central three-quarters of the breadth of tread and round the entire outer circumference of the tyre.
Tyre Condition
A tyre used on a vehicle or trailer must not have any cut or damage to the exterior of the tyre which is more than 25mm or 10 percent of the section width, which exposes the cords or ply of the tyre or any internal or external lump bulge or tear caused by separation or partial failure of the structure. It is a requirement of using a vehicle on the road that the tyres fitted shall be in good condition and suitable in all respects, including inflation pressure, for the use to which the vehicle is being put.
Penalties
It is an offence to use a tyre which has any defect (not just illegal tread depth). The penalty for an offence is a fine at level 4 of the standard scale (currently upto £2,500), compulsory 3 point endorsement and discretionary disqualification. Each faulty tyre is a separate offence.
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
