Old 05-11-2013, 06:25 PM   #11
drbodzin
San Diego Boxster
drbodzin's Avatar
The elastomer layer in the flywheel does not like oil, tends to soften it. Check it for twist per OEM specs, if it is out, it has to be replaced.
I'm able to twist the flywheel about 10mm in each direction by hand. Is it suppose to spring back to the same spot? It goes back, but not with a sudden spring. Sorta "eases" back.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
