Sorry Doc,
You will need to remove the exhaust, at least the muffler portion anyway. Besides, it allows you to be able to "sit up" inside the tranny area to get your IMS in straight and torque the bolts properly.
Make triple sure you lock down the engine at TDC VERY WELL. I used 2 cam locks AND a separate bar on the Flywheel bolts, and the pin in the Flywheel. May have been overkill but I was not going to let the patient die from a timing issue.
There ARE several instructions out there, be careful which you choose!
IMHO @Meir produced the most helpful and best writeups. @Meir's instructions were almost 100% accurate. I consulted instructions from 5 different authors, the least helpful were from LNE. I am not saying any more on the subject.
