Old 05-11-2013, 05:45 AM   #10
Dgnarvs
2001 Boxster S
When you "jump started" the car where were the + and - connections connected?
Pcars are finicky about WHERE you place the jumper cables. Improperly connecting those could be an issue. Notwithstanding that, clean the TB and intake system first. Before you touch the MAF - disconnect the battery (using the negative post). Leave 'unbatteried' for at least 30 minutes - it should take a lot longer to clean the intake system.
Otherwise, my money would be on an AOS. You will be able to see how much 'blowby' is there once you remove the intake. Please consult our DIY here to make sure you do it correctly. This is one of the first things I did to my car and it was disgusting! Make sure you have plenty of paper towels standing by.
Good Luck!
Thanks, HB. I wouldn't suspect that the jump was an issue as the car managed to reach the shop from the house in one piece and without any issues. The problem only materialized after the new battery was installed.
Anyway, I had a suspicion that the AOS needed replacement as there was the telltale smoke the last time I used he car a few weeks back. Stupidly, I ordered the wrong part from Pelican so the right part has not yet arrived. Maybe the 'explosion' was the extreme result of the defective AOS? Not sure though if replacing the AOS would be sufficient to remove the fault code 412.
2001 Boxster S
Arctic Silver
'Brenda' aka Money Trap aka 100% Fun!
Dgnarvs is offline   Reply With Quote
