Old 05-10-2013, 05:39 PM   #12
V-Rod
Newb
V-Rod's Avatar
I just purchased a pair and I noticed that they went in and out fairly easy. So I cut six pieces of 3M double faced foam adhesive and put it on all the tabs. Then removed the backing and carefully put the bottom in first and then the top while holding the tab until the screen was seated and then pressed the tab to adhere it. Oh I also put a strip of foam in the center recess in order for the whole unit to fit more snug. I did not remove the backing from the center piece. It is very snug with no squeaks or rattles.
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
