Old 05-10-2013, 03:02 AM   #5
Kroggers
My car is a racing car and as such not stock - I have a 2001 Boxster s with an early 5 speed box.
One of the projects that I did over the winter was to replace the bent and rusted shift linkage on the transmission to a nice new one. After the change I found I could no longer engage reverse.
Turned out that I had to lower the linkage a fraction - put a washer between the shift linkage and the transmission (two bolts under the transmission that mounts the linkage to the box) - and I could then get reverse again.
Not sure if this will solve your problem or not?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
