Old 05-09-2013, 02:55 PM   #16
jaykay
jaykay's Avatar
The floor is too slick to drive on to the ramps, just pushes them. These are Ebsco jackstands, the best I have seen available @ Pelican. Jack from rear to install jackstands, then jack front up to install Rhino truck ramps. Sat like this for 6 months during engine rebuild.
Got it ...a bit of brain fade on my part. Yeah I have the same exact stands and ramps as you. I have spit them out on concrete let alone a shinny floor like that!!! I recall that Rhino only allows/intends you to use them to lift by rolling up the incline which seems to me that this would be much more stress than gently lowering down on top of them like you have done....must be a liability statement
I think one if my ramps can take 2000 lbs
Did the angle of the car downward to the front help with engine / trans out and back in?
986 00S
