Old 05-09-2013, 07:49 AM   #1
black_box
DIY extremist
black_box's Avatar
2000 Boxster S well loved and maintained / upgraded mechanically
Have been wanting something with the driving dynamics of a Boxster but with more grunt. Toyed with an engine swap, but now have my eye on a CPO 987S, but need to clear my parking spot first.
Car is a 2000 Boxster S. Runs amazingly, very fast (for a 986) and tight. Triple black color scheme with full leather interior, litronics, premium sound, heated seats. 110k on body, engine and transmission much less (details below).
I bought the car in 2011 at 90k with receipts for prior work. It's a higher mileage car, but much of the mechanicals have been replaced or updated. Every time there's been a problem with the car, I've fixed it.
The original engine suffered an IMS failure at 89k, replaced with 25k engine from 2001 car, which means this one has 46k now (with IMS upgraded). 6 speed transmission was pulled and rebuilt with all new parts at the same time (so 21k on transmission). CV Axles, oil filler tube, coolant reservoir, AOS also replaced at that time by previous owner (89k). The cabriolet top has been replaced, and has a heated glass window.
Tires are Michelin Pilot Super Sports with 3k miles, upsized 235/275 on OEM Chromed 18" Turbo Twists (not gaudy looking at all, I love them although I usually don't go for chrome). Have always run Royal Purple full synthetic
Recent Service (done by me):
I have replaced the cabrio microwitch, water pump, accessory belt, and coolant (92k), right rear wheel bearing, air filter, cleaned MAF and throttle body, spark plugs and all six ignition coil packs (one had developed a misfire) at 103k. Clutch, flywheel, IMS bearing, front stabilizer links, front brakes rotors, pads, clutch and brake fluid replaced with ATE Super Blue (108k). Cabrio pushrods replaced and adjusted.
Car has new seats with no wear. Have replaced worn floor mats and 90% of interior plastics that showed wear. Front and rear bumper covers, right quarter panel have been repainted with high quality water based OEM type process due to scratches / door dings. There is a small ding that I haven't repaired on bonnet. Rear brakes need pads soon.
Upgrades:
Bluetooth / line input to stock CDR 220, Secondary Cat bypasses, desnorkel, equal length headers, B&M short shifter. The exhaust setup is quiet with mild driving, but sounds similar to an air cooled car under hard acceleration. Amber lenses switched for clear. I have all original exhaust and shifter parts, along with complete set of exhaust gaskets and will return to stock if desired by buyer.
$15k -- This is a very good car and if you know the 986, you'll see I've taken care of most of the potential issues that secondhand buyers have to deal with.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
