Old 05-07-2013, 06:55 PM   #1
dbazos
dbazos's Avatar
Durametric code results: need help!
Looking for a little help from the Porsche experts in this forum.
I had 2 dash lights on my 2003S lite up a couple of weeks ago: ABS & PSM OFF. I checked for codes with a Durametric short test and got:
P1600. (Fault code 216). CAN timeout PSM
P1601 (fault code 660) CAN timeout - instrument cluster
P0571 (fault code 364) Brake pedal position sensor
What should I check? I checked brake pedal for switch operation and brake lights work fine. I had recently added DEPO LED brake lights; could that cause a problem?
Not even sure where to start with the CAN problem. Otherwise the car runs fine.
Is there a service book available with fault codes and follow up diagnostic procedures?
dbazos is offline   Reply With Quote
