Originally Posted by fritzman
The front suspension seems a bit squirly - not sure if that is a boxster or if some bushings need replacment. Sway bars? Shocks? Are there performance chips?
The Boxster should not be "squirly." I would first check the tire wear as the negative camber tends to chew up the inside of the tires. My box did this and I could feel it while driving over bumps; it would shift abruptly from side-to-side.
A new set of Michelin Super Sports fixed this. :dance:
